Was running with dead spot on accellerator pedal. Idles fine when started after few minutes begins to surge then idles rough and repeats. Car does not stall out.
Codes have included everything from oxygen sensor to max air flow sensor. Reset always comes back to number 2 cylinder misfire. Repair shop says all systems ok no reason for problem can be found.
Could it be vacuum leak? Not able to find problem.
SPONSORED LINKS
Sunday, July 20th, 2008 AT 9:17 PM
