1998 Buick Century Crank
112,000 MILES • 6 CYL • FWD • AUTOMATIC
MAVNKAT
Can a crank sensor reduce spark for starting, and
where exactly on the 3.1 V6 is that sensor located,
and is there a way to test if that is bad?
May 26, 2008 at 1:33 AM
MERLIN2021
  • 17,250 POSTS
Yes or eliminate it, it's locate on the right side of the engine below the exhaust manifold.
Use a volt meter set on 2-volt scale, test the ckp sensor while cranking, you should get 2 volts while cranking, test at the icm by unplugging the sensor input connector and testing across the leads. If the voltage is as specified, the fualt may be the ICM, if not check the CKP at the sensor, if voltage is not 2v change sensor, if it is, check the wires.
May 26, 2008 at 1:47 AM
