1998 Buick Century Blower Fan
180,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGROB69
The heater fan is making a high pitched squealing noise and I assume it needs oiling or replacing. Looked under hood but cannot find access. How do I get to the fan? Thanks.
Jan 24, 2008 at 11:51 AM
BMRFIXIT
  • 19,053 POSTS
[quote:b5aac733e3="bigrob69"]Heater problem
1998 Buick Century 6 cyl Front Wheel Drive Automatic 180000 miles
The heater fan is making a high pitched squealing noise and I assume it needs oiling or replacing. Looked under hood but cannot find access. How do I get to the fan? Thanks.[/quote:b5aac733e3]
if its the blower motor no lube or oil require its a seal unit
you may have to replace it
located at the passenger side inside car under the dash
good luck
Jan 25, 2008 at 8:35 AM
