1998 Buick Century 98 buick century
1998 BUICK CENTURY
LLEFTY22
Engine Mechanical problem
1998 Buick Century
can you tell me how oil is getting into the radiator? and what needs to be replaced or fixed? also can you tell me if there is pressurized oil in the head gaskets? its a 3.1 v6
Feb 20, 2009 at 8:13 AM
ZACKMAN
  • 4,202 POSTS
Oil in radiator is a tell tale sign of bad head gasket. You should have your mechanic perform a leak down test, or at the very least perform pressure test on both heads to see which head not holding the pressure.
Feb 21, 2009 at 4:24 PM
