1997 Buick Century temp sensor
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
DERICK
my 1997 buick century has some type of pronlem with the water temp sensor that i can not find out. I intalled new water temp sensor but the fan will not work when the car engine gets hot, only when I unplug the the sensor.
Feb 4, 2008 at 2:55 AM
BMRFIXIT
  • 19,053 POSTS
[quote:16cadcffb0="derick"]Other Category problem
1997 Buick Century 6 cyl Two Wheel Drive Automatic 120000 miles
my 1997 buick century has some type of pronlem with the water temp sensor that i can not find out. I intalled new water temp sensor but the fan will not work when the car engine gets hot, only when I unplug the the sensor.[/quote:16cadcffb0]
OK
is the engine overheating
and the fans aren’t coming on
do you have check engine light on
what do you have for codes
get codes if check engine light on
Feb 4, 2008 at 11:10 AM
