1997 Buick Century instructions for power window regulator
STEVEN HARRIS
Electrical problem
1997 Buick Century 6 cyl Front Wheel Drive Automatic
I have a 1997 buick century and need to replace the drivers power window regulator any help would be apreciated
Mar 20, 2009 at 10:59 AM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated.. Hope this helps ... let me know REMOVAL & INSTALLATION WINDOW MOTOR Removal Raise window to full up position and secure in place. Remove door panel covering and insulator. Window may be disengaged from regulator and removed from vehicle. If motor is held to door and regulator with nuts and bolts, remove nuts and bolts asnecessary. If motor is held to door and regulator with rivets, punch out center of regulator-to-door rivets and drill out rivets using a 1/4" drill bit. Disconnect window from regulator. Move regulator and motor assembly rearward to access motor-to-regulator rivets. Punch out center of motor-to-regulator rivets and drill out rivets using a 3/16" drill bit. On all models, disconnect electrical connector and remove motor from door. Installation To install, reverse removal procedure. On models attached with rivets, use Rivet Installer (J-34940) with 3/16" rivets for motor-to-regulator attachment and 1/4" rivets for regulator-to-door attachment.
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_325.png
Mar 20, 2009 at 11:14 AM
