1997 Buick Century How do I fix the fan on my car?
1,500 MILES • 6 CYL • 2WD • AUTOMATIC
JULIEK1B
The A/C Heater blower isn't working when I turn it on nothing happens I have a step by step way to do this but need a schematic of the componant panel so when I open it up I know what I'm doing.
Oct 30, 2010 at 5:47 AM
JDL
  • 16,098 POSTS
With key on and hvac turned on, I'd check good voltage and ground at the blower motor, if voltage and ground are ok and no blower action, suspect the blower motor.
https://images.2carpros.com/forum/automotive_pictures/170934_century_blower_motor_1.jpg
Oct 30, 2010 at 6:10 AM
JULIEK1B
What next steps should I use? I am not a mechanic and I have no idea. I just need a step by step way so I can have someone help me check to see. Thanks for the schematic it is very helpful. And do you know how much blower motors costs if this is the culprit?
Oct 30, 2010 at 6:16 AM
JDL
  • 16,098 POSTS
Sorry I can't lead you step by step, I'd have to look at it. If the blower is the problem, the removal and install is listed below. The Napa online partsbook, list the part for 90 bucks plus tax. You might be able to find one cheaper, you will have to look around.
https://images.2carpros.com/forum/automotive_pictures/170934_century_blower_motor_removal_1.jpg
Oct 30, 2010 at 7:59 AM
JULIEK1B
thanks for your assistance. I will check into it when I find someone to help me that is. For today it has been a no go. No one is available perhaps tomorrow. But at least now I can give them this instructions to help Thans so much!
Oct 30, 2010 at 8:11 AM
JDL
  • 16,098 POSTS
In your first post, you said you had step by step, just needed wiring info, which I gave. Sorry if I misunderstood your post. Have a great day.
Oct 30, 2010 at 9:05 AM
JULIEK1B
What I meant by step by step is it tells me to take the panel off and how to use a volt meter to check out to see if it is the relay card or whatever. So that is what I meant but needed the schematic to tell how to test for it. Thanks again.
Oct 31, 2010 at 6:55 AM
