1996 Buick Century Power windows
135,000 MILES • 6 CYL • FWD • AUTOMATIC
VILLAGEIDIOT
4dr sedan. Power window switch (master on driver door) opens only back two windows. Does not open either front window. Power window switch on front passenger side, does not open that window.
Rear switches open their windows no problem. Power lock switches both work on front consoles...
Help!!!!
Jul 30, 2008 at 6:38 AM
JDL
  • 16,098 POSTS
There may be an issue with your master switch. You need to get at the wires on the back side of the master switch. For the driver side door, brown wire terminal E is for up, dark blue wire terminal A is down. If you turn on the key and operate the window switch, one of those wires should be hot, depending on up or down.
Aug 2, 2008 at 6:04 AM
VILLAGEIDIOT
I replaced the switch,
driver power window does not budge (nor does passeger), rear windows accessible from master switch and at their own terminals...
Next?
Aug 3, 2008 at 2:03 AM
JDL
  • 16,098 POSTS
Did you check the wiring colors, I suggested? With the key on and the driver door window switch activated, up or down. There should be voltage on one of the circuits already mentioned.
If there is nothing there, you need to backtrack.
Aug 3, 2008 at 6:18 AM
DINH_PHUONG
I am Haveing A axactly same problem Power window switch (master on driver door) opens only back two windows. Does not open either front window. Power window switch on front passenger side, does not open that window. I am wondering how to resolve it problem.
Thanks
Apr 25, 2009 at 2:03 AM
DI5C0RD1A
centurys seem to be known for their power window problems. I have had my driver side window control switch replaced 3 times now. my driver window was stuck in the down position for 2 days in a minnesota winter. nice, huh?
Also the wiring in the door doesnt connect all the time. but jiggle that big black tube in the door crack and the windows work again!
Oh buick. How I loath thee.
Apr 26, 2009 at 7:15 PM
