1996 Buick Century fuel injection
132,000 MILES • 6 CYL • FWD • AUTOMATIC
ROYTOY
misfire on cyl 5. replaced o2 sensor and cyl 5 plugwire could it be a clogged injector? has plenty of spark off the coil
Dec 3, 2009 at 2:59 AM
JDL
  • 16,098 POSTS
Welcome to the forum, a misfire could be caused by almost anything. Fuel--spark--vacuum leak, anything. If you think it is the injector, you can swap injector with another cylinder. If the problem follows the injector, I suspect the injector.
Dec 3, 2009 at 6:52 AM
