engine just started shaking?
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
CASHIZ_08
well first of all i did have a heavy foot in it, and one day the engine just started shaking and sounds like it's not firing on all cylinders. engine light is on.???
Jul 18, 2010 at 11:54 AM
SQM
  • 6,383 POSTS
As the spark plugs become worn they will start to misfire over time.
Since the engine light is on, scan the vehicle and retrieve the fault codes. It can help pinpoint the issue.
Keep in mind that engine can misfire also due to having bad spark plug wires as well as ignition coils.
Inspect the spark plugs. Check for wear and gap. They should be gapped at 0.060 in.
https://www.2carpros.com/articles/how-to-change-spark-plugs
I have included some helpful information on spark plugs for your reference.
Sep 24, 2021 at 2:53 PM
