1996 Buick Century 96 buick century dies going down road
74,000 MILES • V8 • FWD • AUTOMATIC
CORY EBLEN
1996 BUICK CENTURY LIMITED INHERITED CAR FROM PASSED AWAY GRANDMA 3.1V6 AUTOMATIC CAR WILL JUST DIE GOING DOWN ROAD BUT STARTS RIGHT BACK UP AFTER PULLING OVER AND PUTTING IN PARK REPLACED FUEL FILTER BY TANK TRANSMISSION FILTER AIR FILTER AND PLUGS OLD PLUGS WERE VERY WHITE HELP NO CODES POP UP AND SES LIGHT ONLY COMES ON WHEN DIES IS OFF WHEN RESTARTS ONLY HAPPENS EVERY 75 MILES OR SO
Aug 3, 2008 at 5:53 AM
  • 75,988 POSTS
Attempt to pull the OBD2 code/s or take it to autozone they'll read it for free and comeback with it-we need this information to get a diagnosis started-
Aug 3, 2008 at 5:57 AM
ODDMOORE
  • 12 POSTS
There's a very good chance it's the "Mass Air Flow Sensor". My daughter has a 95 Buick Century, that's been doing the same thing for a couple of months now. At first it was a rare occurance. Then a VERY, VERY frequent one. You drive your car for 10 to 20 minutes and whenever you stop or come to a idel speed it would die, then start right back up. Check engine light comes on more and more. Eventually it's on as soon as you start your car. I used a "Actron Super AutoScanner CP9145 OBDll code reader", to verify my diagnosis and that's exactly what it was. The Mass Air Flow Sensor". Fortunately, it's a easy part to access and remove since it's right on top of your engine. Mine cost, (with a core charge) $136.00 at Autozone. Good Luck. :-)
Aug 25, 2008 at 3:54 AM
