1995 Buick Century service light on car cuts out
112,000 MILES • 6 CYL • FWD • AUTOMATIC
SHIRLEY ROBLES
service soon light would come on car would cut out would not idle had checked scanner showed sensor 131 and 132.replaced 131 sensor on front of motor,but the car is the same if not worse please help. thanks
Feb 23, 2009 at 4:34 AM
THETOOLMAN
  • 123 POSTS
So you replaced the O/2 sensor? It sounds like you may need a fuel filter. The codes you listed are oxygen sensor. If it is a rich condition it may be as simple as changing the air filter. If it is a lean condition then it may be as simple as a fuel filter. The 131 code is a low voltage (Bank 1, Sensor 1) The 132 is a high voltage (Bank 1,Sensor 1) .Did you check the wires going to the O/2 sensor plug? What was the part you changed?
Mar 9, 2009 at 5:40 PM
