1995 Buick Century HeadGasket leak
SLICKXMAN
  • 1995 BUICK CENTURY
  • 6 CYL
  • FWD
  • 98,000 MILES
For the last 4 months for every 800 miles or so I have to add about 2 quarts of oil to the car. The oil is leaking into the watercooling system into the coolant reservoir. The car overheats a little on occasions. But the weird thing is that the water level stays the same I don't lose any water and there seems to be no signs of water in the oil. Is there any other possibilities other than headgasket leak? Also there is no kind os smoke comming out of the tailpipe
Monday, May 18th, 2009 AT 11:46 PM
BLUELIGHTNIN6
  • 16,542 POSTS
From what you have described this is definitely a head gasket failure. While the head is off for replacing the gasket, be sure to have it tested for cracks. They tend to crack, especially aluminum heads, when they overheat a little.
Tuesday, May 19th, 2009 AT 12:22 AM
SLICKXMAN
Thanks for the answer
Tuesday, May 19th, 2009 AT 2:14 PM
