1995 Buick Century fuel scheduling
SALLYANDPETE
Engine Performance problem
1995 Buick Century Front Wheel Drive Automatic 78000 miles
Car "auto-Accelerates" while cold. After car runs for 5-10 minutes on the road if you shut of motor and restart car operates fine. Car wants to run at higher fuel flow/RPM than warranted by gas pedal position
Apr 5, 2010 at 3:46 AM
INTERNETMECHANIC
  • 700 POSTS
Is the cruise control activated when the problem occurs? How long since a tune-up? Any trouble codes?
Apr 5, 2010 at 3:50 AM
SALLYANDPETE
This problem occurs tithout Cruise engaged, have not tried to engage cruise control to see if it would override. Their are no trouble codes form my OBD II scan.
Apr 11, 2010 at 1:22 PM
INTERNETMECHANIC
  • 700 POSTS
Most vehicles will have a higher idle, cold, than they will warm. Does you scanner show live engine data? Look at idle and required idle, they should be close to the same. Is the vehicle in closed loop, when it happens? When you get into, no code, diagnostics, the list of possibilities is as long as your arm. I can list the possibilities if you want, I can't point directly at the problem.
Apr 12, 2010 at 2:25 AM
