1995 Buick Century Does noy get combustion at initial start
62,078 MILES • 6 CYL • 2WD • AUTOMATIC
HUNTERBONE
IT sounded like ad d a dirty air filter..Nope!maybe the plugs were to foul..NOPE! gas filter..NOPE! i Drove today and parked it in the drive way and thought at first i Flooded the carb...NOPE! any Input here would be Great!! thamk you...mike
Feb 16, 2009 at 10:10 AM
  • 75,988 POSTS
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Feb 16, 2009 at 10:35 AM
