1995 Buick Century Car door
CHISOX03
Interior problem
1995 Buick Century Engine Size unknown Wheel Drive Type unknown Automatic 125000 miles
My passenger car door does not open from the inside. You must put the window down and open it from the outside. I'm not sure why it only works from the outside but if there's a cheap way to fix it, I'd appriciate it.
Mar 27, 2008 at 4:57 AM
LEGITIMATE007
  • 5,121 POSTS
somehow the linkage from the inside handle has come off, common problem. you'll have to take off the inside panel and reconnect it. hopefully the piece that connects the two together is still on the rod and not somewhere in the bottom of the door. but if its not there, then just go to the parts department at any buick dealer and they can get that liitle plastic piece , not sure what its called but you can just show them on a diagram that they will provide. let me know how you do.
Mar 29, 2008 at 4:29 AM
