1995 Buick Century Electrical Failures
TUUKDOG
I have a 95 Buick Century V6 with 100,000 miles. It has just recently presented with these problems. The headlights do not work, my powerlocks don't work, my dash lights don't work (except for my clock and radio and my clock and radio presets rest every time the car is turned off), my anti-lock brake warning light is on, and my dome light is out. I have had fuel injector problems recently but those have been fixed for now. A mechanic looked under the dash and the lights and everything started working for him he wasn't sure what he had done and he couln't reproduce the problem. This lasted for a couple days and now all those problems are back. What do you guys think? Thanks.
Oct 22, 2007 at 2:50 PM
BMRFIXIT
  • 19,053 POSTS
[quote:11b6c6e5fe="tuukdog"]I have a 95 Buick Century V6 with 100,000 miles. It has just recently presented with these problems. The headlights do not work, my powerlocks don't work, my dash lights don't work (except for my clock and radio and my clock and radio presets rest every time the car is turned off), my anti-lock brake warning light is on, and my dome light is out. I have had fuel injector problems recently but those have been fixed for now. A mechanic looked under the dash and the lights and everything started working for him he wasn't sure what he had done and he couln't reproduce the problem. This lasted for a couple days and now all those problems are back. What do you guys think? Thanks.[/quote:11b6c6e5fe]
loose wire bad ground
check the batt termin (clean & tight)
check 4 a loose wire
good luck
Oct 23, 2007 at 1:52 AM
Suggested Repair
Clean and tighten the battery terminals, then inspect for a loose wire or bad ground, especially under the dash where the problem temporarily cleared.
Conversation Summary
The owner of a 1995 Buick Century reports inoperative headlights, power locks, most dash lights, and the dome light, along with an ABS warning and radio and clock presets resetting when the car is off. A mechanic briefly restored function while looking under the dash but could not reproduce the fault, and the problems returned. The expert advises checking for a loose wire or bad ground and cleaning and tightening the battery terminals.
