1994 Buick Century windows
BRENT CHRISTMAS
Electrical problem
1994 Buick Century 6 cyl Two Wheel Drive Automatic 60k miles
i need to know where to find the relays for the window motors in the front pass and driver i have checked the fuses and they are fine and both the windows quit working at the same time and thats unusual. I figure it must be a relay.
May 23, 2009 at 8:38 AM
JDL
  • 16,098 POSTS
Hello, did you try using the individual power window switches, passenger front door and rear window switches?
Are you saying the front windows won't roll up and down using the master switch? If so, I'd check the circuits going to the master switch in the driver door.
I didn't see a relay, did see a power window circuit breaker in the fuse box.
May 23, 2009 at 9:01 AM
