1994 Buick Century vibration damper removal (crankshaft pul
1994 BUICK CENTURY
108,000 MILES • 6 CYL • FWD • AUTOMATIC
DALSMI65
1. The center damper bolt has been removed.
2. The camshaft sensor has been removed.
3. I have sucessfully removed one of these from the same 3300 engine in an Oldsmobile.
4. Except for the sensor plates on the back of the damper's the two of them look the same.
5. I could be off one or two on the year. Might be newer.
6. It does not look like any kind of puller would work.
I can't get it to budge..
Any help would be appreciated... thanks
Nov 16, 2008 at 1:30 PM
  • 31,937 POSTS
Hi there ,
All i can find is a reference to removing the pulley with a puller, but i have no mention if it is a special designed puller for the job, you best contact the dealer and check if it is a special tool listing.
mark (mhpautos)
Nov 16, 2008 at 10:08 PM
