1994 Buick Century Parking Brake
SMURRAY2000
Brakes problem
1994 Buick Century Front Wheel Drive Automatic
the parking brake cable broke and the parking brake is on hiow do i release the parking brake?
Dec 20, 2008 at 9:15 AM
JALOPYPAPA
  • 467 POSTS
I'd have to go out and look at mine, but I'm sure the cable releases a ratchet mechanism on the pedal that probably can be disengaged at the pedal.
Dec 20, 2008 at 1:34 PM
SMURRAY2000
the brake pedal or the parking brake pedal??
Dec 20, 2008 at 2:40 PM
JALOPYPAPA
  • 467 POSTS
Get a screwdriver and flashlight and look up under the dash at the parking brake pedal mechanism. Just below the front of the dash nearest you, you'll see a small lever that the end of the release cable may still be visible in. Pull toward you on that lever with the screwdriver and the brake should release.
Dec 22, 2008 at 3:55 AM
