1994 Buick Century Head lights, Tail lights, dome light and
1994 BUICK CENTURY
BUICKGURL_21
Electrical problem
1994 Buick Century Front Wheel Drive Automatic
I just got a 1994 buick century for free and the head lights and brake lights and all the interior lights do not work the fuses in the fuse box seem to be fine I checked them all. I dont know what else to do I don't have the money to take it to a mechanic for them to figure it out and fix it so if its something that I can do by myself then I would prefer that!
Mar 11, 2009 at 1:53 PM
DOCFIXIT
  • 18,828 POSTS
If it is head, tail and interior lights then headlight switch. If it's brake not tail then a few problems they are all powered by different fuses.
Mar 12, 2009 at 7:25 AM
BUICKGURL_21
Thank you for the information and I have one more question on this make and model is there another fuse box located in the car somewhere besides in the glove box?
Mar 12, 2009 at 12:09 PM
DOCFIXIT
  • 18,828 POSTS
Yes under hood
Mar 16, 2009 at 5:46 AM
NICK H
  • 5 POSTS
i had the same problem in a 94 buick century also, if you havent gotten it fixed yet try following the positive battery cable, 1 goes to the starter but it also has a connection off the battery that runs towar the driverside fender unplug the connection and see if anything looks bad, mine was burnt, i cleaned the bad wire connection plugged it in and everything works great now. hope this helps,
Mar 26, 2009 at 9:44 AM
