1994 Buick Century Brakes
122,700 MILES • 6 CYL • FWD • AUTOMATIC
VERMONT200
I have a problem with my brakes in my wagon...I have to press the pedal down almost to the floor for the brakes to start working. There is a leak in the brake fluid, but when I fill it up with fluid, it doesn't fix the problem. Is it something that can be fixed easily, or is it something major? I don't think the pads are worn enough for that to be the problem.
May 19, 2008 at 5:12 AM
  • 75,988 POSTS
There is a leak in the brake fluid, find it and fix it -then bleed the brakes and see what happens-then comeback
May 19, 2008 at 5:20 AM
