1994 Buick Century 94 buick century electrical problems
218,000 MILES • 6 CYL • FWD • AUTOMATIC
NICK H
  • 5 POSTS
I started my car today (in the rain) and the radio went out, I also noticed the headlights were out as well as the brakelights, doorlocks and im sure theres more. I do have turn signals , wipers, ac and heater. when I turn the key to the start position the (Idiot)lights come on then turn the key and it starts but no headlights brakelights etc. If I turn the key on to accesssory I have no idiot lights, heater or ac. All I have in the accessory mode is wipers. All fuses in the glove box are good. Is that my only fuse box? What else can you suggest?
Thank You. Nick
Mar 26, 2009 at 7:53 AM
THETOOLMAN
  • 123 POSTS
Look under the hood to see if there is a Power control center. If so there will be more fuses and relays. I am not familiar with this particular vehicle but I do know that many other vehicles have a power center under the hood as well as inside just take a look. Have you recently added anything electrical? Have you recently replaced any of your lights such as brake dome lights turn signal flasher assembly?
Good Luck
Apr 5, 2009 at 8:00 AM
