1993 Buick Century serpentine belt broke, replaced and now
1993 BUICK CENTURY
193,000 MILES • 6 CYL • FWD • AUTOMATIC
ABWIL2
Hi i have a 93 buick century and my son was driving it when it happened so ill give info that i know. It was almost out of gas and he was going (to gas station which is real close) to put gas in it when the car died. He had no clue the belt had broke so continued to try and start it.Called me when it wouldnt start so i went to him (which was only a block or so away) and he said the belt broke. So we pushed it home and put a new belt on but now car wont start.With him tryin to start it belt looks fine on there but it just wont start. Could it have jumped time? or should i be looking for something else? We put 3 gallons of gas in it with a gas can so it has enough to start but just turns over. Any idieas?
Mar 16, 2010 at 5:43 AM
KHLOW2008
  • 41,814 POSTS
Hi abwil2,
Thank you for the donation.
Check the crank position sensor located near the crank pulley. The belt breaking off could have damaged it.
Mar 16, 2010 at 6:17 AM
ABWIL2
So its not same as Camshaft sensor is it? ive changed that before and i wouldnt think it couldve got that. The crank is the big one at the very bottom? Where may i find a photo of this? Ill search the web . Maybe i can find a diagram of it LOL Thnx
Mar 16, 2010 at 12:15 PM
KHLOW2008
  • 41,814 POSTS
No, the cam sensor is on top whereas the crank is at bottom.
Sorry I could not find any diagrams to show you. The crank sensor is located next to the crank pulley and the serpentine belt breaking would most likely damage it.
Yes, the crank pulley is the big one at the bottom and the crank position sensor is at right of the pulley.
Mar 17, 2010 at 12:18 AM
