1993 Buick Century relay switch
KJOE313
Electrical problem
1993 Buick Century 6 cyl Two Wheel Drive Automatic
is there a relay switch on this vechical if so where is it located problem is turn ignation get nothing from car get under the car can start car from starter
Mar 1, 2009 at 5:20 PM
JDL
  • 16,098 POSTS
Hello, the crank feed to the S terminal on the starter solenoid, usually a purple wire, is it hot with the key in the crank position? Have you tried cranking in neutral?
Might be an issue with the ignition switch or wiring circuit.
Mar 1, 2009 at 11:37 PM
