1993 Buick Century NEED ADVICE ON HOW TO FIX Problem or wha
1993 BUICK CENTURY
15,800 MILES • 6 CYL • AWD • AUTOMATIC
FIGGY1981
I have a 1993 buick century 6 cylinder. I have recently did an engine check and the number code 43 pop up. I know what the code says but i dont know what it means. The code says electronic spark timing (EST) circuit-low voltage detected or electronic spark control (ESC) - circuit problems. Can you please tell me what this means. Thank you.
Jul 14, 2009 at 6:33 AM
JDL
  • 16,098 POSTS
Hello, any driveability issues? Was the check engine lite on? Erase the code, see if it comes back? My info shows that to be a knock sensor code. If that sensor detects a knock, it may retard the timing until the knock goes away. Now, whether the problem is the sensor--wiring circuit-- or an internal engine knock, caused by whatever?
Jul 14, 2009 at 7:08 AM
