1991 Buick Century
JOSHUAOYS1987
  • 1991 BUICK CENTURY
1991 Buick Century 6 cyl Front Wheel Drive Automatic
I recently bought a 91 century and ran into problems immediately. So I got a computer and cam up with code 26 QDM fault. How would one go about fixing this problem? I was told to check my grounds and everything before replacing the ECM but they all checked out. Idk PLEASE HELP! Thank you
Monday, April 12th, 2010 AT 1:02 PM
JALOPYPAPA
  • 467 POSTS
Ah, the helpful GM "Quad Driver" circuit fault code. It means a short or ground in the wiring to any of as many as four miscellaneous components. GM for some reason doesn't like to say more specifically than that. When I got this code, I just started looking at the wiring and soon discovered the wire to the purge canister solenoid was broken (actually, it looked like someone had cut it). I reattached it and everything was fine. I think maybe the torque converter clutch solenoid might be on there and maybe the EGR solenoid, if you have one (my 92 v6 3300 doesn't).
Tuesday, April 13th, 2010 AT 5:40 PM
