1993 Buick Century idle motor
50,000 MILES • 6 CYL • FWD • AUTOMATIC
LMJ
I have hopefully narrowed the problem down the the idle motor. I have been looking for the ecm harness ground with no success. Any help?
Jun 25, 2008 at 1:51 PM
  • 75,988 POSTS
What you have is not a an idle motor-its called idle air control valve-check for foreign material in the IACV bore that might causing your rough idle -if this the case-
Jun 25, 2008 at 2:20 PM
LMJ
it either won't idle, idles fine, or idles about 5 grand
Jun 25, 2008 at 2:50 PM
  • 75,988 POSTS
Inspect and test the throttle position sensor
Jun 25, 2008 at 11:00 PM
