1993 Buick Century fuel system
113,500 MILES • 6 CYL • FWD • AUTOMATIC
XXB0BXX
fuel pump works if i hot wire it at the relay, replaced the relay, no change. Have new 15A fuse and 12 V @ fuse the Voltage drops to 1.4 V when i install the fuse, this is normal???. relay works if i apply voltage to the magnetic coil, if i start car and remove the hot wire the engine stops. I checked all wiring that i could see OK. this problem over night.
What ever you can do for me would be greatly appreciated.
Thank you
Bob
Aug 13, 2008 at 6:30 AM
  • 75,988 POSTS
Did you check the inline fuse 15amp right front of engine compartment on relay bracket and also the fusible link rust colored at the starter solenoid?
https://images.2carpros.com/forum/automotive_pictures/12900_fp1_8.jpg
Aug 14, 2008 at 8:51 AM
XXB0BXX
Yep! I did and found the link from the starter was bad, replaced it and all is good now. thanks for your help. I have another question but thats for another time. Thanks again. Bob
Aug 14, 2008 at 9:59 AM
