1993 Buick Century Drivers door only
ROWSELL
No power on drivers door only, except power windows. remote entry works on other doors and trunk. Door lock control on drivers door works ok on other doors. Outside door handle will not turn on inside lights, other doors ok. Do I have a BCM on this car? Also power outside mirrows not working.
Thanking you in advance for your help.
Oct 30, 2007 at 5:11 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e4d902c0ac="rowsell"]No power on drivers door only, except power windows. remote entry works on other doors and trunk. Door lock control on drivers door works ok on other doors. Outside door handle will not turn on inside lights, other doors ok. Do I have a BCM on this car? Also power outside mirrows not working.
Thanking you in advance for your help.[/quote:e4d902c0ac]
Have u checked the actuator on that door
You may need lock actuator on that door
You don’t have BCM in it
Both mirrors check fuses or switch
Also check the door jam wiring harness
Good luck
Oct 31, 2007 at 12:30 PM
ROWSELL
Found 7 broker wire at door jam, inside of boot. Remover the door panel. Wires were routed under the window and broke when the window was roled down. Repaired wires, then, rerouted all wires to inside of door and tied them back out of the way of the window.
Roger
Nov 4, 2007 at 6:08 AM
