still no start only crank, sprayed starter fluid into manifold
it fired up and then died, check fuel pump to see if it was running when I turned on the key, no sound fuel pump not turning on, so checked the relay fuses under hood 1 was burned so I switched it with 1 not burned just like it still no start just crank, checked the fuel rail to injectors and it has fuel to it.
i'm stumped have never had any problem adding gauges before to any other car or truck but have only
owned fords this is my first buick. Help Please.
Gerald
SPONSORED LINKS
Wednesday, June 25th, 2008 AT 11:56 AM
