1993 Buick Century car back fires
1993 BUICK CENTURY
233,000 MILES • 6 CYL • FWD • AUTOMATIC
BHATFIELD
My car backfires when driving it then stalls and wont start
Jan 15, 2010 at 1:31 PM
Do below
No start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jan 15, 2010 at 8:52 PM
