1993 Buick Century
66,780 MILES • 6 CYL • FWD • AUTOMATIC
MIMIC2010
Im having problems with starting the car Ive changed the fuel filter plugs fuel pump the car often hesatates when you press the gas then stalls out and wont start for20 minutes to an hour
Sep 19, 2010 at 8:52 AM
  • 75,988 POSTS
Check the fuel pressure if okay test the throttle position and manifold absolute pressure sensors
Next time it refuses to start don't wait for nothing do below immediately
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,cap and rotor,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Sep 19, 2010 at 11:50 AM
