1993 Buick Century
1993 BUICK CENTURY
175,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHADBESKA
I have a 1993 Buick Century, and I believe I have an electrical problem with it. When I start the car it runs fine. But when i go to press the break, the interior lights dim. Also when i am using the left turn signal, it flickers very quickly and the whole dashboard also flickers. The right turn signal works fine and I cant seem to find a problem with the fuses. Any ideas??
Feb 6, 2009 at 12:41 PM
  • 110,240 POSTS
Hi:
The rapid flashing sounds like a bulb is bad. Check the socket to see if it's corroded and look for a burned out bulb. Also, check to make sure the body ground (from engine to body) is clean, tight and not damaged.
Feb 12, 2009 at 5:47 AM
