Both front power windows not working, rear windows work fine. There is power to the left front window
Wednesday, June 4th, 2008 AT 10:37 PM
JDL
MECHANIC
For a four-door, my information shows two grounds coming off the master switch, one for the front windows and one for the rear windows, black wires.
You need to get at the wires coming off the master switch. Just to check for a ground issue, you could use a jumper between the two black wires, try to test close to the master switch. If all the windows work, it's a ground issue.
