1992 Buick Century Power steering pump
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
BFLOBIL
I tried to reply using every link...but this is the only way it seems to work. Anyway, I'm replacing the pump..not rebuilding it. The text you sent refers to other drawings...that's what i want..more info on removal....Thanks, Bil
Jan 17, 2009 at 2:41 AM
BFLOBIL
You take my money...send me useless info....don't answer my follow up question...friggin cute....Think i'll ever use your friiggn svc. again? Fact is if anyone asks and even if they dion't I'll tell them who NOT to use!!!! Bflobil
Jan 18, 2009 at 9:27 AM
JALOPYPAPA
  • 467 POSTS
If it's like mine, you remove three bolts through the holes in the pulley and the brace from the back. Remove the lines with a flare nut wrench. Then you can remove the pump from the pedestal before transferring the pulley, for which you will need the special tool. I've never seen a diagram.
Jan 28, 2009 at 5:58 AM
