1992 Buick Century multiple question needing a answer ...
TCPLMB33007
Engine Mechanical problem
1992 Buick Century 6 cyl Front Wheel Drive Automatic
I have a 1992 buick century and i am not understanding with having replaced my spark plugs ,wires ,my car wants to kick over but when i do try to kick it over to start it wants to start but has a sputter like pop as if its going to back fire from the air filter area of the car ,i have also come to smell and see a leak with gas mixed with like oders from what looks as if its somehoe mixing with my coolent from the under belly of the bottom of my car ,its got me so mad i am about to junk it if i cant solve these issues if there is a solution help me please
Jun 12, 2008 at 12:16 AM
JDL
  • 16,098 POSTS
Were you having this problem before you changed plugs and wires? If so maybe you got some of the wires crossed?
Are there any codes?
You might also take the vacuum line loose from the fuel pressure regulator, see if there is any gas in the line?
Jun 13, 2008 at 4:17 AM
