1992 Buick Century misfiring and cutoff
NICOSHANE79
  • 1992 BUICK CENTURY
Engine Performance problem
1992 Buick Century 6 cyl Front Wheel Drive Automatic
my car wont stay started.I have to hold down the gas and hurry up and change gears to go or it will cut off. It also does this at stoplights if I dont put it in park and gun the engine. People tell me I need a tune up but I think its the pcv but I dont know where it is or how to fix it.
Monday, July 14th, 2008 AT 11:43 AM
JALOPYPAPA
  • 467 POSTS
The PCV valve is under the alternator. Other things to check: trouble codes, fuel pressure to the rail, vacuum leaks, operation of all injectors, idle air control valve, sensors: throttle position, MAP, temperature.
Tuesday, July 15th, 2008 AT 2:32 PM
