1992 Buick Century electric windows
70,000 MILES • 4 CYL • 2WD • AUTOMATIC
C.PARON
my front windows (Driver and front passenger) will not go down. THey both quit when my friend and i hit the down swtches simotaneously.
I checked the window fuses and they are both OK
I replaced the main window switch (driver side) and still not working. Both rear windows operate OK and the door lock switch works OK.
I cant see both window motors going badf at the same time. ANY SUGGESTIONS?
Sep 4, 2010 at 10:31 AM
JALOPYPAPA
  • 467 POSTS
It may be that both motors went bad about the same time. Or wiring. One place wires sometimes break is in the rubber bellows between the driver's door and the frame, from the flexing of opening and closing so much.
Sep 6, 2010 at 9:12 PM
