1992 Buick Century crankshaft pulley
BENNY SUGGS
Engine Mechanical problem
1992 Buick Century 6 cyl Front Wheel Drive Automatic 196k miles
I RECENTLY HAD THE C/P R&R AND FOUR {4} DAY"S
LATER I WAS DRIVING ALONG,AN ALL OF A SUDDEN
A "CLUNK" AN THE CAR "QUIT".TRIED TO TURN IT
OVER BUT NO SOAP...TOOK THE CAR BACK TO THE
REPAIR SHOP THAT DID THE WORK.WHILE I WAS IN
THE "WAITING ROOM"I OVERHEARD THE MECHANIC
SAY THAT THE C/P WHEEL IS WOBBLING.SO HERE"S
MY ?..IF THE WHEEL WAS NOT PUT ON RIGHT THE
Ist TIME,WHAT DAMAGE COULD RESULT FROM THIS????AND HOW CAN I PROVE THAT THEY DID THE "DIRTY" DEEED...THANKING YOU IN ADVANCE..
Sep 18, 2008 at 7:38 AM
JALOPYPAPA
  • 467 POSTS
I have had a crank pulley fall off (on another car) for no apparent reason. But the fact it was recently worked on sure sounds suspicious. Maybe the second mechanic could explain what exactly was wobbling. You might ask if they accidentally left off the Woodruff key that keeps the pulley from turning on the crankshaft. It could get very pricey if the crankshaft is damaged.
Sep 19, 2008 at 8:56 AM
