1992 Buick Century changed shift lever, now transmission ma
GRAPHIX
Interior problem
1992 Buick Century 6 cyl Front Wheel Drive Automatic
I removed the pin that holds the shift lever into the column shift and replaced it with a new one (like kind) Now when I shift into reverse or drive the transmission makes a grumbling sound like the gears are not meshing. This sound was not there prior to removing the lever. I even put the old one back in and it still makes the sound. Could something have come disconnected or need to be adjusted? Dan
Apr 25, 2010 at 3:01 PM
  • 110,248 POSTS
If you move the shifter, can you get the sound to stop?
Jun 7, 2010 at 2:17 AM
