If the engine starts with staring fluid it is not an ignition (coil) issue, it is a fuel delievery problem. Since you stated you change your fuel filter and it ran better for a while I would recommend checking fuel pressure, should have 41 - 47 psi. Low or high fuel pressure would cause your issues. Also check the fuel pressure regulator. A quick check is to remove the vaccuum line to the regulator, if there is raw fuel pressent in the vaccuum system, replace the regulator.
Let me know if any of this helps.
Dan
SPONSORED LINKS
Thursday, July 30th, 2009 AT 3:45 PM
