1992 Buick Century Blows a Fuse.
MIKE RICE
  • 1992 BUICK CENTURY
  • 6 CYL
  • 55,241 MILES
I am sure I have a short but would like some help. I blow fuse #9, a 10A fuse, which controls gauges, warning indicator, torque converter clutch, audible warning system, computer command control, trunk release, brake warning light, speedometer and rear window defogger.
The car drives fine with the fuse blown, which leads me to believe it is not the torque converter clutch, but I am curious for some assistance on where to look and how to isolate it.
Thanks in advance.
mike
Thursday, March 13th, 2008 AT 12:40 PM
ED ARMES
  • 129 POSTS
You might start by eliminating as many of the devices that you can as the problem. Unplug everything you can and try it again. If it still blows a fuse then you can eliminate the devices themselves as the cause and start checking the wiring harness.
Thursday, March 13th, 2008 AT 3:15 PM
