1992 Buick Century belt tensioner
150,000 MILES • 6 CYL • FWD • AUTOMATIC
MARKRLR300
  • 12 POSTS
Do I have to take off water pump pipe to replace belt tensioner?
Jun 6, 2009 at 4:04 AM
JALOPYPAPA
  • 467 POSTS
As you may have noticed, the tensioner is built into the power steering pump bracket. I think if you unbolt the power steering pump you should be able to pull the bracket/tensioner assembly straight up behind the heater pipe.
Jun 9, 2009 at 7:57 AM
