1991 Buick Century water pump replacemtn
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
AZUCCARI
What are the tips of removing the water pump on this 91 buick century?
May 15, 2008 at 3:46 PM
LEGITIMATE007
  • 5,121 POSTS
Disconnect negative battery cable. Drain cooling system. Remove water pump drive belt. Disconnect necessary coolant hoses.
Remove water pump pulley bolts and pulley (access hole in body side rail for long bolt). Remove water pump bolts, water pump and gasket. To install, reverse removal procedure using new gasket. Fill cooling system.
May 15, 2008 at 5:05 PM
