1991 Buick Century radiator fan does not come on
MLW0351
Engine Cooling problem
1991 Buick Century 6 cyl Front Wheel Drive Automatic
replaced coolant temp sensor, no engine codes present can still move fan by hand, is it possible the fan motor is bad or fan relay
Aug 6, 2010 at 1:50 PM
BLUELIGHTNIN6
  • 16,542 POSTS
first check fuses, if OK check cooling fan relay located on relay bracket at right front corner of engine compartment. if both OK then supply 12v direct power to fan. if still doesn't run the motor is shot.
Aug 7, 2010 at 4:37 AM
