1991 Buick Century fuel injector pulse
140,000 MILES • 6 CYL • FWD • AUTOMATIC
ZACHARYP
i have a 1991 buick century custom 3.3 v6 , wont start , i have 48 to 50 Psi of fuel pressure , verified spark , checked Tps sensor - tested good , tested Maf sensor - good , replaced knock sensor , replaced crank position sensor , and checked all fuses -fuseable linkes - and relays , all good , ignition module tested good , after all of this I still have no injector pulse , I have tried everything I can think of and am getting noware . Any thoughts
Nov 30, 2008 at 1:33 PM
  • 75,988 POSTS
Turn ignition On-check injector/s connector for power-Do you have it-if so and still won't pulse could be the computer ground drivers-
Nov 30, 2008 at 3:08 PM
HAASER
I have a 1989 Buick Century with the 3.3 engine. It had no fuel injection pulse. I checked crank and cam position sensor, IC module, wiring in between ICM and ECM, swapped out ECM, checked ground wires from ECM to engine, F.I. system fuses, everything was OK. The last thing I did was to disconnect all the F.I. plugs at the rail. All of a sudden there is a pulse! Seems that one of the F.I. coils was shorted out and pulled down all 6 injectors
Jan 1, 2009 at 11:40 AM
