1991 Buick Century failure to run
111,000 MILES • 6 CYL • FWD • AUTOMATIC
AUTOMECHD
The car starts but turns off after a few seconds. I put in a new fuel pump, fuel filter, fuel regulator, new spark plugs, it sparks just won't stay running... What could the problem be?
Nov 14, 2009 at 10:32 AM
JDL
  • 16,098 POSTS
welcome to the forum, thanks for the donation. I saw what you replaced, I'd still have to use a gage and check fuel pressure.
I'm not sure of engine litre size? If you have the bypass ignition system, during cranking it is the ignition module that controls spark timing, after it starts the pcm controls spark timing. Are there any trouble codes?
Nov 15, 2009 at 6:12 AM
AUTOMECHD
the car has no codes.Is a 3.3 engine.Does the tps has something to do,because i check in michell and it said that tps controls the fuel by the pcm.Is that possible?
Nov 15, 2009 at 10:03 AM
JDL
  • 16,098 POSTS
I guess anything is possible, did you check for trouble codes?
https://images.2carpros.com/forum/automotive_pictures/170934_aldl_34.jpg
You place jumper wire between terminals A & B terminals of datalink connector. Turn key on, no crank, then the check engine lite starts flashing, you count the flashes to get the codes.
Nov 16, 2009 at 12:53 AM
