1990 Buick Century no dash or running lights
ARTIEANDERS
  • 1990 BUICK CENTURY
  • 6 CYL
  • 75,000 MILES
My 1990 buick century has no dash or running lights. All fuses in the glove box are o.K. Is there a link or relay somewhere else?
Sunday, April 4th, 2010 AT 10:49 PM
INTERNETMECHANIC
  • 700 POSTS
I'd have to check circuits going to and from, headlamp switch. Your headlamps circuit voltage is not controled by a fuse, there is a circuit breaker in the headlamp switch, only for the headlamp, that part of circuit gets feed from fisible link. Your other circuits, dash lites-- taillites are a fused circuit, does go through the headlamp switch. Use a voltage tester on the instrument lamp fuse circuit, if you haven't already, even if the fuse is good, if no voltage on the circuit, the circuit is dead.
Monday, April 5th, 2010 AT 10:40 AM
