1990 Buick Century
1990 BUICK CENTURY
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
PATSPIMPIN1
girlfriend was driving down the road and everything shut down. no internal light, no headlights, car will turn over but wont start. when you try to start the car then turn the key in the off position and pull the keys out of the car the red temp,oil and batt lights stay on for a few seconds. and sometimes the coil pack starts humming after trying to start the engine and turn the key in the off position it has a new batt, and an alternator that is 1 year old.
Dec 14, 2007 at 1:47 PM
BMRFIXIT
  • 19,053 POSTS
[quote:5eb894d9ee="patspimpin1"]Electrical problem
1990 Buick Century 6 cyl Two Wheel Drive Automatic 190000 miles
girlfriend was driving down the road and everything shut down. no internal light, no headlights, car will turn over but wont start. when you try to start the car then turn the key in the off position and pull the keys out of the car the red temp,oil and batt lights stay on for a few seconds. and sometimes the coil pack starts humming after trying to start the engine and turn the key in the off position it has a new batt, and an alternator that is 1 year old.[/quote:5eb894d9ee]
check fuses and fusible links
on starter you have some fusible link s check it out
let me know
Dec 14, 2007 at 2:07 PM
PATSPIMPIN1
[quote:7bfd416680="BMRFIXIT"][quote:7bfd416680="patspimpin1"]Electrical problem
girlfriend was driving down the road and everything shut down. no internal light, no headlights, car will turn over but wont start. when you try to start the car then turn the key in the off position and pull the keys out of the car the red temp,oil and batt lights stay on for a few seconds. and sometimes the coil pack starts humming after trying to start the engine and turn the key in the off position it has a new batt, and an alternator that is 1 year old.[/quote:7bfd416680]
let me know[/quote:7bfd416680]
just found out that i have a car remote starter, and one of the wires was melted.... dont know if thats the problem, going to try to bypass it and see if thats it.. thanks alot for answering my ?, if you guys have anymore suggestions be sure to let me know thanks alot!
Dec 15, 2007 at 4:02 AM
BMRFIXIT
  • 19,053 POSTS
[quote:9896d9a031="patspimpin1"][quote:9896d9a031="BMRFIXIT"][quote:9896d9a031="patspimpin1"]Electrical problem
girlfriend was driving down the road and everything shut down. no internal light, no headlights, car will turn over but wont start. when you try to start the car then turn the key in the off position and pull the keys out of the car the red temp,oil and batt lights stay on for a few seconds. and sometimes the coil pack starts humming after trying to start the engine and turn the key in the off position it has a new batt, and an alternator that is 1 year old.[/quote:9896d9a031]
let me know[/quote:9896d9a031]
just found out that i have a car remote starter, and one of the wires was melted.... dont know if thats the problem, going to try to bypass it and see if thats it.. thanks alot for answering my ?, if you guys have anymore suggestions be sure to let me know thanks alot![/quote:9896d9a031]
LET US KNOW WHAT HAPPEN OR IF YOU NEED MORE INFO ON WIRING
Dec 15, 2007 at 4:55 AM
PATSPIMPIN1
found out it was my ground, and a purple wire snapped in half. the wire that are in the black tubing. just had to rewire those 2 wires and everything is working fine thanks for the help
Dec 15, 2007 at 8:33 AM
